jeep liberty limited sunroof won't open
Old 03-02-09, 10:25 PM
Norm's Avatar
I have a 2005 liberty sunroof was working properly in summer used often , as the snow has for most part gone I tryed to open sunroof will not open just clicks in the roof i assume at the motor .
It has been warm + 11 there can be no ice holding it shut so what I need to know is why all sudden it won't open or work when was fine last time was used open close normal.
Old 03-03-09, 04:29 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Not sure at what temperature your water freezes, but ours freezes somewhere around 32 degrees. I would suspect any water that has seeped past the seals (and it does when frozen), is still there at 11 degrees, only in a solid form keeping the window from opening. You may can take a hair dryer and run it around the perimeter of the seals, both inside and out and try it, but water will freeze back rather quickly.
Old 03-03-09, 07:23 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
11C is 52F...so doubt its still frozen...lol.
Yes could be the motor..maybe a relay if it has one.
No idea on jeeps though.
Old 03-03-09, 01:34 PM
nightowlpunk's Avatar
On power sunroofs there is normally an emergency opener so you can open it manually if you have to. There might be a pop out panel near the switch which should have the tool for hand opening it.
