Caravan Gauge cluster problem
Old 03-11-09, 02:50 PM
Hello, Our work van's speedo,fuel and temp gauges started going all the way up then all the way down to zero. Then they would work for awhile until you turned on either turn signal. They would then start the up/down thing again. Now everything's dead. It's a 2002 Caravan. Any ideas?
Old 03-12-09, 05:24 PM
HotxxxxxxxOKC's Avatar
You will need to pull the cluster out and check for damaged wiring, but you will prolly have to replace the cluster.
Old 03-13-09, 02:52 PM
That seems to be the answer that we are getting from everyone we have talked to about the problem-replace it. At least it is pretty easy to remove.
Old 03-22-09, 03:04 PM
FYI-the problem turned to be the fuse/relay block under the hood. Lots of green and corroded connections. It might be a common problem as the dealer had the part in stock!! It came with all the fuses and relays installed for about $275.
