how to remove antifreeze smell
I had my leaking heater core replaced over a year ago and it still smells when you turn on the heater. Is there any product or chemical that will neutralize the smell or get rid of it.
If you changed a year ago im suprised you can still smell it. If it aint Leaking you could use a cleaner. If it was me Id probably shoot some brake cleaner or Starter Fluid (which is what id use first) on alittle area to see what it does. If everything is ok douse her down and then blow it all off with some air.
