changing front brakes
Old 03-18-09, 07:29 PM
Hi, I am newbie. I have Nissan Sentra XE 1998.For the first time I am going to change front brakes Discs and pads.Since I have not changed the brake oil past 4 years,will it be good if I can change this too? If yes, can I follow the following steps?
1. Bleed right rear brake.
2. Then Change the disc and pads of front left brake and bleed it also after changing.
3.Then bleed left rear brake.
4.Then Change the disc and pads of front right brake and bleed it also after changing.
Thanks a lot in advance.
Old 03-18-09, 08:35 PM
G
in easy way to test this to get brake fluid test ph paper to test the condition and how much moisture is in your brake fluid. it is a good thing to change, as for your procedure and this make and model i'am not sure.
Old 03-20-09, 06:02 PM
D
as for which wheel always start with the farthest wheel away from the brake fluid resivior and move to the next farthest usually rear passenger then rear driver then front passenger and then front driver wheels and always a good idea to do..
