power window
Old 03-26-09, 07:18 PM
O
Unhappy power window
I have a 2004 Grand Prix and the rear window on the passengers side will no longer go up & down. I can pull it up but it falls back down. I can hear the motor when I push the window button but nothing happens. I need to know how to remove the door panel so I can see whats going on in there.
Old 03-28-09, 04:51 PM
D
You should get to a parts shop and buy a Haynes manual for that car.
The Haynes are a cut above the Chilton, etc.
I was able to do that exact fix on a Camry following the procedures outlined.
Be patient; you'll probably need a top quality roll of duct tape to hold the glass up while you do the work.
Old 04-13-09, 09:51 PM
F
Haynes manuals are the way to go! You'll be able to fix this in no time.
Old 04-15-09, 10:40 AM
nightowlpunk's Avatar
Sounds like you have a bad window regulator. That is a common problem on Volkswagens with power windows.
