Noisy tires
Old 04-02-09, 05:40 PM
Tolyn Ironhand's Avatar
Noisy tires
Long story short: I put some used rims and tires on a car that I'm going to sell and now I get a lot of road noise from them.
Is there anything I can do to quiet them down?
Old 04-02-09, 06:01 PM
Some tread designs are noisier than others. Did the used tires have even wear?
Not much you can do with the tires themself.
Old 04-02-09, 06:34 PM
If the tires are feathered, or cupped they will make noise, if there is enough tread on them you can have them trued, it might help.
Old 04-02-09, 08:21 PM
rt_truong's Avatar
You can try balancing the tires.
Old 04-02-09, 08:57 PM
nope nothing.. the rubber gets harder with age causing more noise plus as said the tread patter will tell how noisy it is
Old 04-03-09, 03:24 PM
Thanks for the adjective Wire Twister! I believe you are correct! They are feathered. They don't seamed cupped but when you run your hand one direction they seam normal and in the other, they are rough.
I guess this is a non issue because it sold today. Thanks for the info all!
