2001 concorde lxi egr fault
is it still called an egr or another name on a 3.2 duel cam engine,where is it located on this engine
Yes it is still called EGR....
Im not good with the "Years"....so Either Drivers side, off to your right, of the Intake manifold, Or, Back edge of the passenger cylinder head.----
Either way, look carefully for a 1/2 diameter steel tube and a grommet on the manifold....Once you find the tube follow it down to the valve....And there you are.
