1992 GEO Storm lights
Low beams dont work. All other lights work. Possible they burnt out same time? If not, what could it be?
Possible...also check for seperate fuses for high and low, as well as headlight relays. Autozone.com may have wiring diagrams
both headlights were working and then i went to go out and they werent. Does the headlight relay control both low and high on this car. Could the high beams work and low not and still need the relay?
