Dodge 5spd manual trans
Old 04-24-09, 07:23 AM
BSB's Avatar
BSB
BSB is offline
1998 Dodge Ram 1500, 5.9L, 4x4, 163K
Shifting into 1st or 2nd while stopped is a real pain and usually requires shifting into one of the other gears and then it will slip into 1st/2nd. If the truck is rolling it shifts into 1st and 2nd no problems. While driving shifting is smooth, no grinding, no hesitation. Once it goes into 1st/2nd (while at a stop) I can shift in between the two with out resistance.
Once in a while when I come of the highway 5th gear seems a little sticky . I'm wondering if maybe the shifting mech is slightly out of alignment or maybe the trans fluid needs replacing.
Other ideas or knowledge?
Thanks.
Brian
Old 04-24-09, 03:17 PM
Unclediezel's Avatar
Worn Synchronizer rings.........
The fluid in a manual trans is ONLY for lubrication , and performs absolutely NO other task( unless you wish to consider "Cooling " as a function). So changing it accomplishes nothing.
Is the clutch in good shape?... A worn disc can give similar symptoms, but would cause the issue at all times. Shifting between 2 gears to "Smooth " them out, is a tell tale for Synchros.....Any Grinding between gears?
Old 04-24-09, 05:44 PM
chandler's Avatar
Is it a diesel or gasser? With my 3500 diesel I found that (silly as it may seem) if I move my seat one notch forward, I tend to press my clutch more fully and the gears change better. Likewise coming to a stop when cold, I have to wait until it rocks before it goes into first. But clutch condition has alot to do with it.
Old 04-27-09, 04:41 PM
BSB's Avatar
BSB
BSB is offline
Thanks for the responses. It's Gasoline, no grinding when shifting. Have adjusted seat in case I wasn't depressing all the way. Will check the throw of the clutch this weekend to make sure it's fully disengaged. Once when it wouldn't shift I turned off the engine and toyed with it a bit, with and with out the clutch still wouldn't shift into 1st/2nd, sometimes 3rd. Started back up, put it in reverse backed out and continued on my merry way.
