Easy brake fluid removal tip
Old 05-08-09, 07:33 AM
nightowlpunk's Avatar
I am not sure if I heard about it here, from someone else, or thought of this myself. An easy and safe way to remove brake fluid is to use a turkey baster available at grocery stores for $3 or so. Just dip the baster in the reservoir, use the bulb to suck up the fluid and then put the tip into a bottle and squeeze bulb to remove. I have found this a great way to remove brake fluid without spilling it. I mentioned this to a guy at the grocery store this morning, and he thought it was a great idea. Sorry if I stole someone else's thunder with this tip.
Old 05-09-09, 06:37 AM
HotxxxxxxxOKC's Avatar
That's has always been the way to get it out of the reservour, but there is still lots of fluid in the brake lines themselves. I would not change my fluid this way anyways. I would rather bleed the brakes while replenishing the fluid until the fluid is clean coming out the calipers.
Old 05-09-09, 11:09 AM
True but it does come in handy when an oil change place tops off the brake fluid and you need to push the caliper bore back when changing pads.
Old 05-10-09, 11:24 AM
This method is also used to change the power steering fluid in the reservoir. It's called the "turkey baster method". Great minds think alike.
Old 05-10-09, 03:45 PM
I certainly hope that no one uses these basters in the kitchen afterward.
Old 05-10-09, 03:49 PM
Gunguy45's Avatar
Super Moderator
Hey a little P/S or brake fluid could probably lubricate the old gritty knees......
Or substitute for that old olive oil...lol
Trackbacks are On
Pingbacks are On
Refbacks are On
