06 Kia Spectra 5 AC problem
I have an 06 kia spectra 5 that is having an ac problem. When I turn on my air it blows room temp. When I turn my AC on I hear the compressor come on. I was told that if the compressor comes on then my freon level is fine. I've had the freon check and they said it was full. Any ideas to what the problem could be??
A/C problems are best diagnosed by bringing them into a mechanic. They have the tools to properly find the problem.
If your compressor does turn on and you actually do have good pressures, then I would look into your blend door inside the vehicle. This little flapper opens or closes to either let the heat of the heater core to enter the air vents, or the cool air from the A/C. If the blend door will not close, you will not get cold air.
