2000 dodge grand caravan 3.8
Old 05-09-09, 07:19 PM
when i drive about slow speed less then 65 km after one km roughly start vibration and slow down slowly--if i drive 80 to 100 km dped so less then km strt vibration AND I HAVE TO PULL OVER AND AFTER STOP IF AGAIN DRIVE IS GOOD BUT AGIN AFTER LESSTHEN A MIN, AGAIN SAME VIBRATION START , ACCORDING TO MY OBSERVATION IT MAY BE FUEL FILLER IS NOT GOOD , PLEASE I NEED ADVICE ASAP WHAT I Have to do-----
Old 05-09-09, 08:33 PM
Unclediezel's Avatar
I'll bet your check engine light is on as well??????
When your PCM detects a misfire, it shuts down fuel to the offending cylinder to prevent Catalyst damage. Shutting the Ignition off, resets the misfire counter and returns the fuel delivery to normal until a misfire is again detected...Then starts the process over........
Have the codes pulled and correct the cause of the misfire, and problems solved....
Old 05-10-09, 06:31 PM
vibration when drive-
some one told me after test drive it my be drive shaft has to change both of them because after certian speed vibration start-i dont know it may be
