2005 Pontiac Vibe A/C problem
Old 05-17-09, 06:02 AM
My daughter has a 2005 Vibe. The blower doesn't work. You can feel the cool air coming out of the vents, just no air flow. Where/what should I check first? Thanks in advance.
Old 05-17-09, 11:08 AM
check your fuse if that is ok check your relay ? then if not then check for proper voltage at the fan motor if its good then replace fan motor
