1996 Plymouth Breeze A/C compressor
Old 05-18-09, 06:28 AM
Red face 1996 Plymouth Breeze A/C compressor
The A/C compressor doesn't work, but if I connect it directly to the battery positive it works properly.
I don't know if It has a relay or fuse? and where are they?
Old 05-18-09, 09:51 AM
the_tow_guy's Avatar
It will likely have a relay and a fuse, not necessarily in the same location. Have you checked owners' manual for locations?
Old 05-18-09, 10:01 AM
Gunguy45's Avatar
Super Moderator
And it seems some cars (yours may not) have controls so that the compressor won't run if the charge is too low or pressures are too high.
I've only read that (here, IIRC), not a mechanic.
Old 05-18-09, 10:04 AM
Good point, Guns; I was answering the direct question without thinking beyond.
Old 05-18-09, 10:17 AM
Ok, I will check the manual for the fuse or relay location.
I have an other question, the system must have pressure in range to work? Or the compressor is independent? Because the system has not pressure.
Old 05-18-09, 10:20 AM
Are you saying the system is empty?
The low-pressure switch, if it has one, is independent of the compressor; I think the one on my wrecker is attached to the drier.
Old 05-18-09, 10:26 AM
Gunguy45's Avatar
Super Moderator
As I said..it may need proper refrigerant levels and pressures to work correctly. Operating the compressor without the required levels of lubricant and refrigerant in the system can damage it. I see two sensors available in parts at Autozone, one just says pressure sensor, the other says high pressure sensor. SO it may very well need exact range of pressures before it will cut on.
You would need to wait for a mechanic to answer specifically
Old 05-18-09, 11:00 AM
Ok guys, I will fill the system and let's see what happen.
