timing chains and belts
Old 05-22-09, 10:19 AM
nightowlpunk's Avatar
Is it possible to put a timing chain in a car that currently uses a belt? The reason I am asking is that I do not view chains breaking as easily as a rubber belt. I got my timing belt changed a few months ago because my water pump was starting to go south. The previous owner got a door welded shut instead of replacing the latch, so I figured that the timing belt was WAY overdue to be changed at the time because I had put 50k on the car after buying it.
Old 05-22-09, 12:33 PM
the_tow_guy's Avatar
No, it is not. Timing belts are external and non-lubricated. Chains are internal and oil lubricated.
Old 05-23-09, 11:14 AM
Thank you much for clearing that up.
