2001 Saturn Transmission Problem
Old 05-27-09, 06:53 PM
I have a 2001 Saturn SL2, 1.9 liter engine, 4 speed automatic transmission. When shifting from 2nd gear up to 3rd it will slip for a second ,then shift in hard, jerking the car. it also slips shifting from 3rd down to 2nd, and when shifting from park into reverse (normal idle speed, nothing wrong there). i have changed trans fluid, the old one was clean and clear.
any known problems with that cars trans, and a diy fix? Thanks for any Info,
Mark
Old 05-30-09, 04:11 PM
Square Head's Avatar
Question
If the unit is slipping there's an issue. You are also experiencing "Bang-Shifting" which is not good at all.
Has the unit ever over heated?
Did you change the filter when the pan was off?
Was there any metal filings?
It could be a shift modulator in the valve body / accumulator spring.
It's hard to say but the problem sounds serious.
Old 05-30-09, 06:24 PM
Unclediezel's Avatar
Fluid filter and all the "FLUSHES IN THE WORLD" will not repair a daamged clutch pak.........
Its time to have the unit professionally serviced.....
Old 05-31-09, 08:50 AM
I agree,
If you don't know how an auto trans works, you should take it in to a reputable shop. It sounds like clutch pack / valve body issues. When it's bang shifting, it could easily mean a fatal issue for the unit.
