03 Pathfinder Transmission Flaring
Old 06-14-09, 01:28 PM
jayedmo's Avatar
I own an 03 Pathfinder SE with 63000 miles on it. Just recently, the RPM would flare up before switching to the next gear. Long story short...brought it back to dealer who "fixed" the problem.
It started doing it again, but this time only in 2nd gear.
It only does this when the engine is cold, but once I've driven it for about 10 minutes or so, it no longer flares.
Any ideas? Thanks in advance.
Old 06-24-09, 12:49 PM
i have a friend who had the same issue. replaced the filter.. an whatever fluid we had to drain out.. seemed to cure it for now. might check to be sure the fluid is full. perhaps there is a leak ? if your low on fluid the tranny will shift oddly...
