changing o2 sensor
Old 06-14-09, 03:44 PM
changing o2 sensor
Do I have to disconnect the battery when changing a rear o2 sensor?
Old 06-14-09, 05:16 PM
if it makes you sleep better at night sure, but in reality you dont have to just plug and play. if u want to erase the codes u can dissconnect the battery for 30 seconds or so then reconnect it. start you engine than wait about mins or so for the computer to relearn itself.
good luck,
redneck_sputter
Old 06-15-09, 05:12 AM
the_tow_guy's Avatar
That may or may not work depending on what vehicle it is and the year. As redneck says, there's no reason to disconnect the battery just to do the sensor.
Old 06-15-09, 03:17 PM
nightowlpunk's Avatar
From looking at a Hayne's manual, it is downright amazing how many things you are supposed to disconnect the negative battery cable. I am almost surprised they do not tell you to disconnect the battery to change your oil.
Old 06-16-09, 04:58 AM
That's because the lawyers get hold of the manuals before they go to press.
Old 06-16-09, 10:16 AM
Kind of figured that much. Wouldn't this country be a lot easier if the word lawyer never existed?
