rear brakes 2006 subaru outback
Received 0 Votes
Is there a special tool required to replace rear brakes on 2006 subaru outback wagon?
Received 0 Votes
That's a little bit of a vague and tricky question. I don't believe you'll need any special tools to change the brake pads per se, but you will want to bleed the brakes and a power bleeder or vacuum pump comes in handy for that.
If you have done brake jobs previously, then you shouldn't have much trouble figuring out this car.
Check out this write-up:
http://www.subaruoutback.org/forums/...&postid=174588
It's for a 2004 Outback, but should be the same brakes as your 2006 if I'm not mistaken.
Previous Thread
Next Thread
