1998 2.0l 4 cyl. Dodge Avenger timing belt
Old 07-30-09, 10:46 AM
I can't get the right engine mount bracket off the front cover of the timing belt. I was able to remove the top long bolt but have the two side bolts loose the bracket and cover are loose but I can't get it pulled up or sideways to get it out. anyone have a trick for this? very tight area,
Old 07-30-09, 04:07 PM
Unclediezel's Avatar
...Been there done that ....
Floor jack under the oil pan, raise the motor up, (It goes up higher than you Think)...Wiggle the mount bracket out with the bolts still in the bracket......Just remember to put the bolts back in the holes ahead of time when you reassemble.
