VW Cabriolet won't start
Old 08-03-09, 09:34 PM
My VW Cabriolet 1988 won't start. No spark even through cap rotor and coil all check out!
Old 08-10-09, 09:44 PM
carguyinva's Avatar
does the distributor shaft/rotor spin while cranking? if not, check for a broken timing belt. might want to be sure it's in time also.
to check triggering you can place a test light from coil negative to ground and you should get a flashing light while cranking.
