99 Chevy Blazer headlights won't come on
Old 08-04-09, 06:15 AM
We have a 99 Chevy Blazer and the headlights won't come on. When problem first started, if you hit the dash right below the light switch it would work. Also the daytime running lights still worked - at first. Now the daytime running lights don't work and the headlights won't work no matter how hard you hit the dash. Any suggestions?
Old 08-04-09, 12:21 PM
G
Received 2 Votes on 2 Posts
It could be the switch, but just to rule out headlights, check and see if they work on high beam. If so, replace one side with a new bulb and see if you now have low beam on that side. If so, replace the other side. If you can't remember replacing them in the past, they could be ten years old and burned out.
