no air coming from vents
Old 08-05-09, 07:13 PM
W
i have 2000 Astro van when i put the blower on there is no air coming from the vents als when a/c is on there is no air coming out
any help would be appreciated
Old 08-05-09, 11:03 PM
Do you mean the blower isn't working or it is and not out of the vent/def or floor? If the motor isn't running check fuses relays and the resister pack if all check out good then try to feed power directly to the blower motor and see if it works if not then you need a motor if it does then the problem lies in the control panel. If the motor is running then you have a bad actuator for the diverter door or a vacume leak to the actuator. I can't recall of the top of my head but I don't believe the door was electricaly controlled in 2000 if it is then the motor is bad or the panel is still the issue.
Old 08-06-09, 06:57 PM
W
the blower motor is working so it might be a vacuum leak will have to check it out i dont think it has a motor
