ford taurus noise
Old 08-06-09, 06:09 PM
D
ford taurus noise
Hello,
I have a 1997 ford taurs with automatic transmission. Sometimes when I'm stopped I hear a sound when I place my foot on the gas. It's hard to explain the noise. It seems like an exploding sound but at much much lower volume. It doesn't happen every time. Can anyone tell me what this is? I recently had the oil pump for the transmission replaced. Could it be related to that?
Old 08-07-09, 05:18 AM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
Possibly something loose in the exhaust system and you are hearing that.
Old 08-07-09, 05:32 PM
R
i wonder if it's a misfire. if it was a misfire the check engine light would be on. is it on?
Old 08-13-09, 11:45 AM
D
It is a misfire. It's gotten a little worse and that's what it sounds like. The check engine light has been on for several months due to a bad camshaft position sensor. Would fixing the camshaft position sensor fix the misfire?
Old 08-14-09, 06:01 AM
Good possibility and good place to start. Also any routine maintenance items; plugs, wires, etc.
Old 08-17-09, 07:21 AM
Square Head's Avatar
If the cam position sensor was not working, I doubt it would run at all. It could be related to the knock sensor not working. Have you had the codes pulled from the computer??
