neutral start switch
Old 08-11-09, 05:22 PM
Thumbs up neutral start switch
auto will not try to start, no click or starter noise when you turn key to start engine. selnoid and starter ok, good battery.
what purpose does switch serve except to keep you from cranking car in gear?
Thanks
Old 08-11-09, 05:29 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Exactly what you said. You can jumper the switch to see if thats the problem. May be as simple as an adjustment. Look for bad/dirty connections as well.
Old 08-11-09, 05:30 PM
Unclediezel's Avatar
The only other function it MAY have is Reverse lamps...
Year MAke and Model??????
