2001 jimmy
Old 08-12-09, 06:00 PM
Question 2001 jimmy
Hello everyone,
I have a 2001 jimmy with 170k miles and recently 2 pc of rubber hoses burned. The connection originates with 2 metal pipes that are connected to the motor exhaust manifold on both sides. Proceeds with 2 rubber 90ís (that melted on 1st occurrence and burned hardness) continues with metal hoses, rubber again and to a T(melted on 2nd occurrence).
The third hose is connected to some type of motor at the bottom front of the vehicle.
I would like to know what causes this problem and what to do to solve it.
Thank you very much in advance to all who will provide info.
Old 08-12-09, 06:20 PM
Unclediezel's Avatar
Sounds like a Clogged Catalytic converter....
The "Motor" on the bottom front is an air pump.....It circulates fresh air to the manifolds.....If the exhaust gas cannot get out, it backs up and blows out the check valves......There is no reason why hot exhaust gas should be in those hoses other than an exhaust restriction, or failure of BOTH check valves.
Is the Check engine light on??????
Old 08-12-09, 07:52 PM
2001 jimmy
Unclediezel,
about the engine check light there is no away to know at this time because, according to the mechanic that inspected the suv last time, the light is burned.
I suspect that if working, the light would be on.
Regarding the check valves and catalytic converter, how can I determine which one is bad or maybe both?
Thank you very much
Old 08-12-09, 08:46 PM
Since the check valves are already damaged (ie..The hoses burned off)....I would suspect the Converter as the likely culprit....
A question......Does it seem to run better after the hoses burned off????
Old 08-13-09, 09:20 AM
2001 jimmy
Hello again,
The suv does not run any better, it started to hesitate when starting drive, and some times loosing power (acceleration) for a few seconds wile driving.
