03 Caravan Rad fans not working
Old 08-13-09, 12:27 PM
Hi,
I have 2003 dodge caravan 3.3L engine 90000 km .yesterday i was driving with the AC on all the time and when i parked my van and let it run idle the temp gauge shot up to high .i let the van running idle and checked under the hood and fans were not working and i can hear clicks from fans trying to run .so i let the van get cool and drove again with AC off and worked perfectly no problems so i assume that the problem is with the Relay .is it faulty relay or thermostate and i also checked the top hose which is pretty hot so that means thermostate is working fine .any suggestions guys.
Old 08-13-09, 01:29 PM
i have just tested the fans directly they are working fine and i just took my van for a ride with AC on all the time and when parked in idle fans kicked in and working fine but i still have engine light on .
Old 08-13-09, 04:45 PM
Unclediezel's Avatar
Ok....
Within 3 seconds...WITHOUT Cranking the engine...Cycle the ignition key --ON-OFF-ON-OFF-ON..... There will be a code displayed in the odometer window......What is it?????
