2002 Saturn Vue Trans/electrical problems???
Old 08-16-09, 02:12 PM
Exclamation 2002 Saturn Vue Trans/electrical problems???
I have a 6 cylinder automatic were the transition goes into high gear while driving and should be in a lower gear. If you stop the car, turn it off then back on it goes right back into the normal driving mode. The service engine light does come on but I have not been able to get it to a mechanic before the codes clear. If you do not start the car every few days the battery goes dead and the codes clear. We replaced the battery thinking that there may have been a bad cell but the new one will also die if the car is not started every couple of days. Does anyone have any ideas as to what could be wrong?
Old 08-16-09, 05:55 PM
HotxxxxxxxOKC's Avatar
Just because the service light is not on, does not mean codes are being stored. I'm having trouble trying to figure out what your problem is. What do you mean it should be in a different gear? If your new battery is dead as well, then your alternator is not charging it, or something is drawing the battery dead when off.
Old 08-17-09, 03:10 AM
When driving in a lower gear it will just go into the highest gear feeling like it went into neutral (car does not go anywhere when this happens). The only way to get it back into the lower gear to drive again is to turn the car off then back on (sounds like this resets something).
When the battary dies the codes are clearing based on what we were told from the shop we took it to. We tried taking it there after charging the battery and they were not reading any codes. Thet suggested that we drive it until the lights come on and try and get it back in before the battery dies. It sounds like something linked to the trans problem is draining the battery because the alternator will keep the battery charged as long as you drive the car. The battery seems to die shortly after the codes appear. Does this help any?
Old 08-17-09, 04:02 PM
I don't think anything in the transmission could cause the battery to drain. Also, if you are not getting the correct voltage (alternator), you will have issues like you have because there is not enough juice to the computer modules.
Old 08-17-09, 05:01 PM
if the check engine light is going on the pcm is probly detecting a condition/fault in the trans, if it is a condition that the pcm thinks could cause damage it will put the trans in limp mode defaulting the trans in second or third gear all the time. as for the dead battery u should check your alt output or for parasitc drain
Trackbacks are On
Pingbacks are On
Refbacks are On
