95 Buick Regal Automatic Transmission Lock/Park on the Column Function
Old 08-26-09, 01:20 AM
Any help would be appreciated ...
My 95 Regal will no longer go into Park position and lock. Car continues to roll like neutral position. Auto Trunk mechanism won't work. Car will not start in Park position but will start in neutral.
But other than that, transmission shifts just fine and normal
Someone looked at briefly and said a cable of some sort would need replacing?
Any thoughts?
Thanks in advance, Bill
Old 08-26-09, 04:05 AM
If the shifter is on the column then the linkage is either worn or mis-adjusted, if it has a floor shifter then it will be a cable that needs adjustment or repair.
Old 08-26-09, 08:13 AM
its definitely on the column.
what would be the difference in linkage or a cable?
Old 08-26-09, 01:58 PM
I may have mis led you. Is this a front wheel drive car? If it is it is cable shifted weather it is column or floor shift, and it needs adjustment.
Old 08-26-09, 10:16 PM
front wheel drive with on the column shifter
could be an adjustment needed and not a cable needing full replacement??
many thanks for your time, Bill
Old 08-27-09, 06:15 AM
Shifter
Because it worked well for years and is now problematic I would think something has changed. If it's a cable then it likely needs a new one due to wear. If it's linkage it likely needs a bushing of some sort. You need to due some mechanic type stuff and grab a light and look for the looseness.
Bill
Old 08-27-09, 06:40 AM
I would check the neutral switch. The switch at the end of the shift cable where it attaches to the transmission body--this switch tell the transmission which gear you have selected from inside the car. Something might have gotten misaligned--if you have a repair manual it will show you haw to check that everything lines up and how to re-adjust the cable should something have been pulled, thus resulting in some possible cable slack etc. . . .
Old 08-27-09, 06:59 AM
A neutral safety switch keeps the engine from starting while in gear and it operates the reverse lights. It shouldn't have any effect of transmission function. The newer electronic transmissions utilize a computer processor in the shifter assembly that works differently and can cause all types of problems.
Bill
Old 08-27-09, 10:36 AM
When you move the shift lever throught the gear choices, do you feel the 'dents' at each gear selection?
If not maybe you cable now needs adjustment.
In my 95 altima I have to adjust the cable at the neutral switch.
Old 08-27-09, 12:41 PM
all is fine now. had the cable replaced as it was separated at the end of the cable due to age and use (this is a taxi)
many thanks to all who took the time to respond and help
this forum is right on!!
again, many thanks, Bill
Trackbacks are On
Pingbacks are On
Refbacks are On
