high idle
Old 09-11-09, 02:24 PM
high idle
95 gmc jimmy 4x4 224000mi while driving car wanted to stall as if no gas then would idle real high, repaced tps under warrenty at az ,when i remove tps plug idle stays the same,any help in this would be appreiciat K
Old 09-11-09, 08:01 PM
Square Head's Avatar
Lightbulb
Take a look at the IAC valve / Idle Air Control valve.
You can remove it and soak it in liquid wrench for a few hours. Just soak the bottom valve area, not the electrical plug.
Clean it good as it gets carbon build up and sticks.
Dry it out with compressed air and use a new gasket when re-installing.
Old 09-11-09, 08:20 PM
95 does not have IAC valve, it is throttle body injection. Check for a vacuum leak at the gasket between throttle body and intake, or loose throttle body attaching bolts.
Old 09-12-09, 04:21 AM
this 95 is the ob11 version of the crossover year .there was no code for iac but thats what ill be looking at today[figures it raining but it has to be done i guess.I also thought it may be a vaccum leak. thank guys ill let you know later how i made out . also how can i check for vaccum leaks as i do not have any tools for it.
Old 09-12-09, 06:48 AM
Smile
heres what i have so far, removed iac and sprayed with thottle cleaner,cleaned throttlebody both at iac and the t body.first atemp got the high idle then tried again and it went back to good idle. drove about12mi with stop and start interviles and all so far seems to have done it,knock on wood. if i get again im going to change out the iac. will write again if repeat. thank you guys very much for the info K
Old 09-13-09, 08:49 PM
Ensure all vacuum hoses are tight and no splits.
Did you use a new gasket for the IAC?
I'd start pricing out a new valve as well. Try Rockauto.com.
Post back and good luck.
