removing beverage holder tray
Old 09-17-09, 11:39 AM
Roeboat109's Avatar
ON a 98 ford windstar the beverage holder underneath the radio how do you get it out?I'm wanting toinstall some fog lights and thats the only way i see of reaching where i want to go because the book shows that the fog light switch hole is supposed to be to the right of the rear window washer and deicer. Appreciatted any feedback.
Old 09-17-09, 03:04 PM
HotxxxxxxxOKC's Avatar
Pull the tray out all the way and see if there's a clip. Usually using a flat head screwdriver you can release it and pull it all the way out.
Old 09-17-09, 04:55 PM
hopkinsr2's Avatar
Does the holder assy have 2 holes on each side of it one above the other??? I'm thinking these pull out using the same raido tools you use to pull the raido But it's been a while since I've had a Windstar apart... If it does you can sometimes sneek 1/8" cotter pins in to release then.. You'll need 4 pins.... Roger
Old 09-17-09, 05:37 PM
Roeboat109's Avatar
removing cup holder
I found the removal instructions in my haynes book.It comes out just exactly like an ashtray. Thanks for your response.
