Car not starting even with boost battery
Old 09-21-09, 07:05 AM
X
Chevy Lumina APV 94 120 000 Miles
I left the car parked for a week then it would not start. The battery was at 0 Volt. (zero light, zero radio, nothing)
I got another car (actually 2 different ones) to boost it. Pushed the foot down on the battery-car (to get >3000 RPM), but old car won't start.
It makes a weak sound as it wants to start (not the sound of a dead battery). The starter turns just a bit then nothing... as if a week person tries to make an effort, like pushing a car...
The boost cable gets hot.
I need this car for another 800 miles before letting it go!
Any suggestion?
Thank
Old 09-21-09, 07:09 AM
the_tow_guy's Avatar
Received 51 Votes on 41 Posts
Need to get a new battery in it; yours is a goner and is impeding the effort to jump start.
Old 09-21-09, 08:29 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Yep...a boost with jumper cables is just that, a boost...it won't normally start a completely dead battery in a car. Also, your battery could be internally shorted which will really cut the amount of juice actually getting to the starter and such, and will never let it build even a partial charge.
They are sometimes called "booster" cables...never starting cables.
Old 09-22-09, 04:23 AM
X
Worked
Thanks The_Tow_Guy
Learning that a dead battery would prevent starting, I connected my booster cable from this car to another one and just let the latter's engine idle for 20 minutes. Then I hit the starter. Bingo!
I will try it again today and most likely will get a new battery.
Thanks
