driver side door does not open from inside
Old 09-27-09, 05:55 PM
91 olds cutlass ciera. the driver side front door no longer opens from the inside. it opens from the outside but not the inside. the handle moves but does not open the door. did a cable break? is this something i can replace myself?
Old 09-27-09, 06:01 PM
chandler's Avatar
Yeah, but you would have to remove the door panel to see exactly what broke or came loose. Some use cables and others use linkages. Hope yours was simple. Just take a 5n1 tool and pry the panel from the door, undoing the screws in the hand hole and wherever you feel pressure.
Old 10-19-09, 06:51 PM
the handle is broken. I managed to remove 2 screws that held a black cover plate on and noticed that there was a broken hole on the handle were a cable or something would have attached.
