2002 Pontiac Bonneville - Windshield Washer Not Working
Old 10-01-09, 11:38 AM
We replaced the Winsheild Washer Motor thinking it was that and it still isn't working...doesn't seem to be getting any fire...checked the fuse and that is fine too! The only fuse we could find associated was under the hood...#3 i think...there are more fuses under the back seat....Anyone run into this or have any ideas??? )
Old 10-01-09, 01:47 PM
Turn the ignition ON.
Press the windshield washer switch.
Do the windshield washers operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
3
Disconnect the windshield washer pump connector.
Connect a test lamp across the washer pump connector terminals.
Does the test lamp illuminate?
YES Go to Step 10
NO Go to Step 4
4
Test the windshield washer pump ground circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES Go to Step 14
NO Go to Step 5
5
Test the windshield washer pump control circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES Go to Step 14
NO Go to Step 6
6
Disconnect the windshield wiper motor connector.
Connect a test lamp from the windshield wiper switch signal 2 circuit terminal in the wiper motor harness connector to ground.
YES Go to Step 12
NO Go to Step 7
7
Test the windshield wiper switch signal 2 circuit for high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES Go to Step 14
NO Go to Step 8
8
Inspect for poor connections at the windshield wiper/washer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES Go to Step 14
NO Go to Step 9
9
Replace the windshield wiper/washer switch. Refer to Windshield Wiper and Washer Switch Replacement - On Vehicle in Steering Wheel and Column.
Is the repair complete?
Go to Step 14
10
Inspect for poor connections at the windshield washer pump. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES Go to Step 14
NO Go to Step 11
11
Replace the windshield washer pump. Refer to Washer Pump Replacement .
SORRY CANT PASTE THE SHEMATIC ON THIS SITE
Go to Step 14
12
Inspect for poor connections at the windshield wiper motor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
13
Replace the windshield wiper motor. Refer to Windshield Wiper Motor Replacement .
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition
