97 Stratus Auto Transmission replacement
Old 10-04-09, 09:35 AM
O
I have a 97 Stratus, 2.4 engine, Automatic transmission.. The transmission is out of it and i have gotten one from a salvage yard to replace it. I was looking at the Chilton repair manual and it said that after the replacement was finished i had to hook up some kind of scan tool so the transmission could "learn"
I have swapped transmission on several other cars in past and have never run into this. is this necessary???
Thanks
Vic
Old 10-04-09, 10:04 AM
Unclediezel's Avatar
Technically ....Yes....
Real world.....No
It may just act a bit funny for a short while, but it eventually will learn by itself......
The scantool process is referred to as "QUICK-learn", for that very reason....
Old 10-04-09, 12:18 PM
E
Thanks
Vic
On a transverse mounted engine like this, do you have to take the car almost all apart to get one out? Does the engine need to come out with it? I look down into the engine compartment of such cars and shake my head. Can't imagine going through that much work? Good luck on your project.
Old 10-04-09, 04:47 PM
O
Real world.....No
Thank you for the info!!!
I figured as much but wanted to be sure, I definately don't want to go to the work to swap it and then screw it up!!!!!
Old 10-10-09, 02:26 PM
O
Another question on this vehicle and transmission,
is there a seperate computer for the trtansission or does it use the main.?
Thanks
Old 10-11-09, 04:31 PM
B
Two computers; I hope this is an apple-apple swap.
Old 10-11-09, 07:21 PM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
Not sure if a Stratus tranny swap is a bargain; anybody remember if those are somewhat problematic generally?
