Removing the horn button/steering wheel cover
Old 10-06-09, 04:54 PM
Does anyone have instruction/pictures of how to remove the horn button cover on a 98 buick skylark? I can feel two holes on the back side of the steering wheel on either side that I ASSUME to be screw holes but I do not know for sure.
Any help will be appreciated.
Old 10-06-09, 05:13 PM
Those are screw holes, most likely 7mm heads on them, but also possible that they are phillips headed screws.
Old 10-07-09, 01:26 PM
So taking these screws out will get the cover off?
Thanks.
Old 10-07-09, 02:48 PM
yes, but unhook the battery first, there will be a wire attached to the horn button and if you let it touch any metal it can blow a fuse.
Old 10-08-09, 06:24 AM
Thanks for the help. The fuse is already out but I will unhook the battery anyways.
