need help with fixing my car
Old 10-10-09, 11:37 AM
I have a 1987 Pontiac Trans Am GTA. It has been sitting in my garage for about 6 months, since the last time I started it up. Is this car messed up, or can I just change the oil and fluids?
Please help if you can, I really need to get it fixed soon.
Thanks
Old 10-10-09, 12:10 PM
Gunguy45's Avatar
Super Moderator
Unless they are due for changing anyway, I wouldn't even do that. Charge/replace the battery if needed, check air pressure and fluid LEVELS and try to start it. Now...if you want to be a little extra cautious, disconnect the coil wire and crank it until you see some oil pressure on the gauge. Then reconnect and start it.
6 months isn't really that much, I left plenty of cars sitting outside for 7-10 months, with the battery cable disconnected, when I was on deployments. Came back, connected the cable and they fired right up.
Old 10-11-09, 07:55 AM
A 1987 Pontiac Trans Am would probably have a HO 305 engine and a 700R 4 transmission.
Long term storage is not a problem with that year of vehicle.
Newer vehicles has a computer and security that runs all the time and in time the battery goes dead and the computer goes into a fault mode and you have issues.
I would say for you to have the oil changed, if it is ready for a change and check all the filters and the tire pressures.
Storing a vehicle in a garage doesn't hurt it one bit.
Old 10-11-09, 08:29 AM
help with car
http://www.alpharubicon.com/altenergy/gaslifepal.htmse
Here is an interesting post along the lines of storage
