General Ford Question (old generation)
Old 10-16-09, 04:24 PM
What side of the starter selonoid does the postive battery cable go on? (the firewall side or the headlight side)
My educated guess is the firewall side but unsure and I know there's a ton of talent here who knows for sure.
Its a '67 Mustang but Ford used this setup for over about 30 plus years.
Old 10-16-09, 05:03 PM
pugsl's Avatar
Received 62 Votes on 58 Posts
been years since I worked on one but if I remember right solenoid will not operate if cable connected backward. I think battery side is closes to battery.
Old 10-16-09, 05:40 PM
A
Received 2 Votes on 2 Posts
The cable will not cross in front of the solenoid.
Battery goes to the closest, or headlight side.
Old 10-16-09, 05:47 PM
Yep, from the video and pictures I've taken at car shows the positive battery cable goes on the battery side/headlight side of the selonoid.
Old 10-16-09, 06:03 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
with a 3 terminal solenoid:
it doesn't matter as long as you have the correct aux wires with them on the same side as the larger wire they are correctly associated with.
with a 4 terminal solenoid:
I'm still looking, I keep finding conflicting info.
Hey guys,
what happens if somebody puts the solenoid on upside down from what you are thinking?
Old 10-16-09, 06:24 PM
A
best I remember, I had a 66 Mustang, there would be 4 wires:
2 large wires:
1 from the battery and to the car feed
1 to the starter motor
2 push on wires, 14 gauge or so:
1 to the ignition switch
1 ignition resistor bypass
The solenoid needs to be grounded to work.
I have never seen one mounted upside down.
Old 10-16-09, 07:52 PM
nap's Avatar
nap
nap is offline
New Member
You have never worked with me. It doesn't matter which way it is mounted.
yes but which is which?
I
those do make a difference.
S= switch (control)
I= ignition (feed back to the bypass resistor)
the battery should be connected to the large terminal closest to the S term.
Old 10-25-09, 08:00 PM
Well, it turns out that I had the smaller wires on the wrong side of the seloniod and caused the engine to crank as soon as I put the key to the run position.
Thought that I had a bad wire in the harness shorting to ground......after a couple of days of tracing wires I discovered the correct wire in the circuit that energizes the starter and it goes from the ignition switch to the nuetral safety switch.
I even thought of this first but discounted it.
All along the nuetral safety swicth was bad so I jumped it and she roared to life..........sounds great for a 42 year old 289.
This is the first time I've ever heard it run.
Bought it 10 years ago and I've been rebuilding the body from the ground up since.
