1999 Cadillac Power Antenna
The nylon mono filament that pushes the antenna mast up and down snapped. Motor is good, just need to find replacement filament or complete power antenna unit. Where do I start?
Used to be able to get a mast kit for those things, this saved you from buying a new motor every time, thats the way to go if it is still available. Might even be available from the aftermarket by now.
Power Antenna
Thanks wire twister. I checked with the dealer. They have a mast I can make fit. Might end up going that way. Tanks again.
