94 f150 power steering pump removal
Old 11-03-09, 03:31 PM
P
my truck has a captive ,power steering pump, which appears to require the removal of the pully before I can remove the whole bracket holding the pump. there doesn't seem to be room for the power steering pully puller I can get from my parts dealer. Do I have to remove the radiator, cowling etc to do this or is there some other way
Old 11-03-09, 04:37 PM
hopkinsr2's Avatar
No,, I've pulled lots of these & there is no need to pull the rad.. Are they getting you the right puller?? I'm almost thinking not.... Roger
Old 11-03-09, 04:50 PM
the_tow_guy's Avatar
Received 176 Upvotes on 138 Posts
Should look something like this:
Amazon.com: PULLEY REMOVER Power Steering Pump/Alternator: Home Improvement
I'm thinking like hopkins that you're trying to use some big jaw-style puller.
Old 11-03-09, 07:06 PM
N
what engine do you have?
"I" remove the pump from the truck-then pull the pulley off.
it will take a 'ford' only installer to install the pulley.
Old 11-04-09, 03:12 PM
P
why only a ford puller
the puller that I can get is definitely a power steering puller with to sizes to fit over two different hubs, it is not a jaws type puller the issue is the length. I am tempted,since I can get the bolts part way out and they turn freely to just cut them off, remove the remainder and replace them. I am concerned that I don't damage the pump when I replace the pully which will have to be done when in place after being bolted back in. Does the ford puller do something special and baecomes a replacement tool?
Old 11-04-09, 07:15 PM
N
'i' do not understand,-what are you trying to do?
"you did not indicate the engine"?
in my case(i work for a ford dealer)- 1st-remove the pressure hose
& the return hose.
remove the pump-& pulley-,as an assembly.
put pump in a vice- use puller to remove pulley.
post-back/-or pm if you still don't understand.
Old 10-20-10, 02:52 PM
do you allways have to pull the puley before you can remove the pump, i have a 92 f250 460 motor with air?
