2007 Ford Fusion caliper piston won't tighten
Old 11-17-09, 04:42 PM
I have swapped out the Pads & Rotors on my 2007 Ford Fusion. Driver's side went fine. Passenger side, when I try to tighten in the piston on the caliper, it turns but does not go in enough to allow enough space to fit the pads around the rotor. Any idea how I can get that piston in further???
Old 11-17-09, 04:50 PM
hopkinsr2's Avatar
Is it front or back your working on??? The front should just squeeze in but sometimes the rear need a bit of push to get them to go.... Assuming it is the rear your working on & the "E" brake is part of the caliaper.... Roger
Old 11-17-09, 04:54 PM
Hello, Thanks,
It is the rear. I turned it in clockwise, but I did not really put inward pressure on it. Is this why it didn't go in enough?
Old 11-17-09, 05:00 PM
hopkinsr2's Avatar
Maybe,,, I know I've ran into trouble with some & it seemed if I squeezed some with my channell locs while I turned them, they would go... Good Luck, Roger
Old 11-17-09, 05:05 PM
Thanks Roger,
I'll give it a shot in the A.M.
Joe
Old 11-17-09, 06:10 PM
there is a 'tool' made for this.
possible the parts house has one for rent.
Old 11-18-09, 02:54 AM
pugsl's Avatar
If you are having that much trouble pushing piston in you probably need a caliper.
