Oil hand pump-any good
Old 11-26-09, 08:17 AM
B
Is it OK to use a OIL EXTRACTOR HAND PUMP to change the oil or is it better to drain the oil through the plug.I was always told the oil should be warm to change and draining would get all the garbage in the very bottom.
Old 11-26-09, 08:39 AM
N
if you do a little searching, this was debated back & forth about 6 weeks ago
Old 11-26-09, 09:58 AM
the_tow_guy's Avatar
Received 62 Votes on 51 Posts
Better = plug.
Old 11-26-09, 04:16 PM
A
I would say if the oil filter is under the car so that you have to raise and crawl under there anyway, might as well drain it from the plug. If the filter is accessable from the top of the engine, you might as well use the sucker. That's how Mercedes does it. The few ounces of old oil left shouldn't make any difference.
