Check eng. soon light
Old 11-27-09, 05:01 PM
2001 Grand Am 3.4, Bad thermostat eng. ran hot gauge read about 100 deg. Eng hot/ rad cold. I replaced the thermostat gauge reads normal around 200 deg. I disconnected the batt to see if service eng soon light would go out. The light is still on Will it reset itself after some miles get put on?
Old 11-27-09, 05:21 PM
Take it to advance auto. They will normally read the code for free and reset it for you as well. I bought a code reader from them several years ago for like $75. Pays for itself if you ever have to rescan.
Old 11-27-09, 05:29 PM
Thanks for the reply & the info about buying a scan tool. After I posted I thought maybe the car running hot caused somthing else to fail.
Old 11-28-09, 04:55 AM
the_tow_guy's Avatar
Depends on what caused the light to come on in the first place. Definitely get a scan so you will know what codes were set before you reset the light.
Old 11-28-09, 05:33 AM
chandler's Avatar
Is it a CEL or a check engine "soon" light. That is usually an oil change warning instead of a code related issue. Get the codes read, but I believe it is resettable at oil change time.
Old 11-28-09, 09:39 PM
After about ten or fifteen miles the check eng. soon light went off. Now I will get the oil changed. The car has an change oil light also. Thanks for the replies.
Trackbacks are On
Pingbacks are On
Refbacks are On
