Power Brake Booster - 1994 Thunderbird
Old 12-05-09, 12:13 AM
tbird94's Avatar
Vehicle: 1994 Thunderbird, V8, w/ABS
Two years ago, I had the booster replaced in my ’94 T-Bird. Now, it seems to have gone bad again – sounds like air leaking and the brakes don’t work right.
Question: Could something else be causing the booster to go bad?
I'm the original owner. The original booster lasted 13 years.
Old 12-05-09, 07:55 PM
hopkinsr2's Avatar
Is the air leaking from under the dash??? Under the hood?? Only when you push the brake pedal or only in drive & reverse?? Does the pedal fade if you hold your foot on it??? Do you have the automatic park brake release??? There are a lot of things that can cause brakes not to work right,, It would help a lot if you were more specific,, (eg,, pulls, pulses, fades, noises & lots of other stuff,) Give some more info & the pros will help you out in no time.... Roger
