Idle speed just a little high
Old 12-08-09, 05:25 PM
Angry Idle speed just a little high
I have a 1993 Ford Explorer when i am in park with the engine the idle is a little to high should i replace the Idle Air Control Vaive are is their something else i need to check out
Old 12-08-09, 06:05 PM
chandler's Avatar
Received 3 Votes on 3 Posts
It may be you can turn the idle screw a little bit to reduce the rpm's. Check that out before you go replacing things.
Old 12-08-09, 07:03 PM
hopkinsr2's Avatar
I'd be looking for a vacuum leak.... Roger
