no injecter pulse
Old 12-23-09, 11:48 AM
no injecter pulse
i have replaced the (comp got 3) module, pickup,distrubator,fuel pump,coil,wiring harness old one was green and conectors where falling off.what am i missing or what can i do to make my truck run.it starts when u put stuff in the throtlebody.how do i check to see if i have a injector pulse and where is it located.i am in need of help and dont know what to do now.thanks for your time
Old 12-23-09, 04:25 PM
chandler's Avatar
Need to know make and model to help. If it is a Chevy, when you turn the key on you should hear a 1 or 2 second buzz. That's your fuel pump pressurizing the lines. If you don't hear it, the pump (in tank) could be toast. I fixed mine once by turning on the ignition and hitting the bottom of the gas tank with a rubber mallet a couple of times. After the second hit I heard it buzz. Could have had trash in it somewhere.
Let us know the info on the truck and we'll try further to help.
