insallation for new fog lights wiring harness
bought new fog lights for a 2005 toyota corolla, (new install) they did not send the instructions for the wiring harness hookup. It would be so much easier to read the directions then to guess. Any input for the install. Thanks
Welcome to the forums! I found that on many cars and trucks, they are already wired for fog/driving lights. Do you see a fuse position marked fog/driving lights? If not, you should mount your lights, mount your switch. Find a fusable power source or use the inline fuse that comes with the kit, run the hot lead to the middle or bottom connector on the switch. Connect the other wire to the other connector on the switch and run it to the fog lights in tandem. Ground each fog light to a good metal grounding point and it should work.
