Blower Blows Off and On
Old 01-03-10, 07:24 AM
kinkyraggae's Avatar
I have a 2004 Suzuki Forenza and my blower works off and on...mostly off. It does not blow anything whether it is heat or a/c. When I switch the blower from level 3 to level 4, it gives a clicking sound on the driver's side to the left of the steering wheel. I'm not sure if it is coming from behind the dash or under the hood at the firewall. Occassionally if I hit a bump or pothole really hard it will turn on and stay on. But if I park the car and come back out after a while...it does not work again. What could this be?
Old 01-03-10, 07:50 AM
chandler's Avatar
Received 4 Votes on 4 Posts
You probably have a bad relay/breaker for the blower. While you are under the dash, turn on the fan and heat and listen for the clicking. Then put your finger on each relay to feel the clicking. Pull that relay and replace it. If the new one does the same, you have major surgery to do. But we'll cross that one when you get there.
