Fuel Pump Relay
Old 01-04-10, 01:46 PM
Fuel Pump Relay
Where can I find the Fuel Pump Relay in my Mazda B2600 (gas engine) pick-up?
Old 01-04-10, 02:27 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Welcome to the forums! Most all relays on newer vehicles are located in a panel under the hood. You didn't say which model you had, so if it is older, it could be under the dash.
Old 01-04-10, 02:44 PM
Thanks for your response. It's a 2003 -2005 Model B2600.
I think I found it under the passenger seat side panel. But there are more than one relay there. Would it be a Denso
Z5A1?
Old 01-04-10, 03:07 PM
chandler's Avatar
Not sure, but look on the door to the kick panel, there should be a fuse/relay listing with a picture of location on it. It will say fuel relay, or fuel pump.
