Buick Regal 96 3.1L 6cil thermostat replacement help
Old 01-13-10, 10:16 AM
C
Exclamation Buick Regal 96 3.1L 6cil thermostat replacement help
I'm changing the thermostat in my car for the first time, and need some help. I'm pretty sure I found it, but I can't get to the bolts, let alone get the new thermostat in there, I have some pics I'm going to post. I need to know what to take off, to get to the thermostat.
some pics
Old 01-13-10, 10:20 AM
the_tow_guy's Avatar
Received 48 Votes on 38 Posts
Hi, and welcome to the forums. I don't have a definitive answer for you right at the moment. While you're waiting for an answer from one of the others you might try checking the repair manual section at autozone.com. I can tell you that the slotted part in the top picture will be the bleeder valve for getting air out of the system after the work.
Old 01-13-10, 10:24 AM
Just took a quick look at autozone and it's pretty optimistic in the instructions (most repair manuals are ). it basically says remove the two bolts, take off the elbow, and remove the thermostat. Obviously they left out the part about removing other items interferring.
Old 01-13-10, 11:03 AM
C
go figure lol
Ya I cant even reach my hands down to feel the 2nd bolt at the moment, Got a helpful answer on getting to it and putting it all back together though on another forum xP
"oh fun fun! you have a good one..here are the proper replacement steps..
Disconnect the negative battery cable.
Remove the air cleaner and duct assembly.
Partially drain the engine cooling system, into a suitable container, to a level below the thermostat.
Remove the engine torque strut bolt from the engine.
Disconnect the upper radiator hose from the housing.
Properly relieve the fuel system pressure.
Disconnect the fuel lines from the fuel rail.
Remove the heater hose bracket at the thermostat housing stud.
Disconnect the heater hose from the throttle body.
Unfasten the thermostat housing retaining bolts, then remove the housing.
Remove the thermostat. Remove and discard the gasket.
To install:
Thoroughly clean the gasket mating surfaces.
Position the thermostat, then install a new gasket.
Attach the thermostat housing to the inlet manifold. Coat the retaining bolts with RTV sealer before installing them. Tighten the bolts to 18 ft. lbs. (25 Nm).
Connect the heater hose to the throttle body.
Install the heater hose bracket at the thermostat housing stud.
Connect the fuel lines to the fuel rails.
Attach the upper radiator hose to the thermostat housing.
Install the engine torque strut-to-engine bolt.
Install the air cleaner assembly, then connect the negative battery cable.
Refill the engine with the specified type and amount of engine coolant. Start the engine and check for coolant leaks."
thats what I got so I should have it fixed before the days over xP I'll post back how it goes
